Recovering crashed project
dbeldowicz
Post by dbeldowicz » Wed Apr 15, 2015 5:53 pm
I'm have a similar problem..how can I recover this audio?
But "The attachment’s file size is too large, the maximum upload size is 2 MB."
so i have put it on dropbox
https://www.dropbox.com/s/l11nijhvfz22h ... osave?dl=0
Let me know
Thanks
Dan
Re: Recovering crashed project
Post by steve » Wed Apr 15, 2015 9:35 pm
Topic split.
Please do not hijack other peoples topics.
Please do provide the information requested in the pink panel near the top of the page.
Post by Gale Andrews » Thu Apr 16, 2015 10:02 pm
As you may have seen in other topics, in case like this you need to open the AUTOSAVE file in a text editor, then remove the long line which is empty except for </project> at the end of it, and remove any other empty lines.
The last two lines of the AUTOSAVE file should then look like this:
Code: Select all
</recordingrecovery>
</project>
Here is the repaired file https://www.dropbox.com/s/nz0by2nbmpyrw ... save?dl=05
