Feedback when recording with imported audio
gertlers10
Post by gertlers10 » Wed Apr 15, 2015 9:25 pm
Hi,
I'm running Audacity 2.1.0 on Windows 7.
When I import an mp3 file into Audacity and record over it on a new track while listening to the imported mp3, the recording cuts in and out and sounds like there is feedback. When I take the mp3 file out and record only my voice on the track, the recording quality is fine.
Not sure what to do about this.
Can anyone help?
gertlers10
Re: Feedback when recording with imported audio
Post by gertlers10 » Wed Apr 15, 2015 9:35 pm
I'm using headphones plugged into the computer's headphone jack.
Post by steve » Thu Apr 16, 2015 12:05 am
gertlers10 wrote: and record over it on a new track while listening to the imported mp3
What are you recording? Are you recording vocals over a backing track? Are you using a USB mic? What settings do you have in the device toolbar?
Post by Gale Andrews » Thu Apr 16, 2015 9:32 pm
If the problem persists after choosing the correct recording device the mic is connected to, see these tips: http://manual.audacityteam.org/o/man/fa ... .html#sync.
