mp3 issues
GullibleCraug
mp3 issues
Post by GullibleCraug » Wed Apr 15, 2015 6:59 pm
I am having an issue saving a project as an mp3 file. I go through the process of saving it as an mp3 file and selecting the right format etc. When i view it in a folder it's not a .mp3 file, it's just a file. I have the latest version of lame encoder installed and in the plugins folder in the app data for audacity. Yet it still will not save as an .mp3 file. What have I done wrong?
The file format
Re: mp3 issues
Post by steve » Wed Apr 15, 2015 8:09 pm
Please provide the information requested in the pink box near the top of the page.
Note that to create an MP3 file you must "export" from Audacity. The "save" command only produces Audacity projects, not audio files.
Re: mp3 issues
Post by Gale Andrews » Thu Apr 16, 2015 10:44 pm
GullibleCraug wrote:I am having an issue saving a project as an mp3 file. I go through the process of saving it as an mp3 file and selecting the right format etc. When i view it in a folder it's not a .mp3 file, it's just a file. I have the latest version of lame encoder installed and in the plugins folder in the app data for audacity. Yet it still will not save as an .mp3 file. What have I done wrong?
If you used the File > Export or similar command to export MP3 and Explorer shows just "File" then you probably added a dot (period) into the file name, and ignored the warning Audacity gave that you may not be able to play the file.
If you want to put a dot in the file name, add
Code: Select all
.mp3
after the end of the name before exporting.
See http://manual.audacityteam.org/o/man/fa ... extensions.
