Blue Yeti only makes feedback noise when recording?
So I just bought my blue yeti, and was really excited to use it. I plugged it in and pluuged my headphones in to it to hear myself and it sounds crystal clear. However, when I open audacity and press record, I get this weird feedback noise...I've attached it below. This only occurs when recording, but if I open reaper, when I arm the track I hear it. When I open sound recorder, I hear it.
What is going on? I don't want to use noise removal because it makes the voice sound bad. I've tried on multiple computers, in multiple rooms, multiple USB ports, I even attempted using a powered hub. Could it be the microphone itself?
- Attachments
- Yeti Feedback.mp3
- (161.63 KiB) Downloaded 121 times
Re: Blue Yeti only makes feedback noise when recording?
If you really love to record internet sound, no doubt you're used to using Stereo-Mix or one of those services. Stereo Mix is also known as "Everything Playing On The Computer." So when Audacity goes into record, it picks up everything active on the machine and sends the mixed signal back to the microphone/headphone connection which is what Overdubbing does. So no, I'm not shocked that you have completely scrambled sound.
However, I'm not a Windows elf, so all I can do is guess at the solution. In all cases you have to select devices and services that you can touch and feel. In Audacity, select your microphone specifically in the device toolbar. Stereo Mix is a program, not a device. You can't touch it.
http://manual.audacityteam.org/o/man/de ... olbar.html
If you intend to play older tracks into your headphones while you sing a new one, then you need the complete overdubbing tutorial.
http://manual.audacityteam.org/o/man/tu ... rdubs.html
One of the steps in this tutorial is set up to make a simple recording. If you can't do that, then all the later steps will just drill you a hole deeper and deeper. It appears that the Yeti is one of the microphones that can do a good job of perfect overdubbing — once you set it up.
When I did the tests, I did them with a Samson G-Track microphone.
It's a good bet it has a lot of the same setup instructions as yours.
- Quality Assurance
That noise is "normal" with USB devices. You have not recorded loud enough to mask the noise. Your words should be up to +/- about 0.5 on the blue waves. Do you have the mic slider turned up in Audacity?
I actually do have the Blue yeti set as my recording setting, not stereo mix! I don't intend to do singing on it, I'm using it for video voiceover.kozikowski wrote:One of the steps in this tutorial is set up to make a simple recording. If you can't do that, then all the later steps will just drill you a hole deeper and deeper. It appears that the Yeti is one of the microphones that can do a good job of perfect overdubbing — once you set it up.
Reason: trim quote to relevant reference and fix quote tags
Is this really normal? It's pretty loud during silence, and you can even hear it when I'm speaking. I also do have my settings in Audacity turned all the way up, with the gain all the way down on the mic.Gale Andrews wrote:That noise is "normal" with USB devices. You have not recorded loud enough to mask the noise. Your words should be up to +/- about 0.5 on the blue waves. Do you have the mic slider turned up in Audacity?
- Quality Assurance
You have said nothing about your version of Windows or your computer.
Yes it's pretty "normal". If you have a laptop, the USB interrupts are often shared so you get the noise from the USB modem, USB mouse and other peripherals.
The recording is not loud enough. You are not recording far enough above the "noise floor". Are you close enough to the mic? Even in your test, the noise is not severe. You can reduce the noise below -60 dB in Noise Reduction without creating artifacts in your words.
The gain should be turned up to a reasonable level on the mic, and then adjust the recording level on your computer to suit.Kyler45 wrote: I also do have my settings in Audacity turned all the way up, with the gain all the way down on the mic.
If your mic has a "clip light" on it, turn up the mic gain until you can just make the clip light flicker on when you speak at the maximum volume that you will be recording (or just a bit louder than that), then turn down the mic gain a smidgen so that the clip light does not come on.
Ahh, sorry about that! I'm running Windows 7 home premium 64-bit on my desktop. I attempted on my Windows 8.1 Laptop too, and got the same noise. I thought I was pretty close to the mic, but I may be wrong. What level ideally should my microphone be in recording settings? I honestly didn't think it did anything because it didn't sound any different in my headphones that were plugged in to the mic (Which obviously makes sense looking back on it, it's picking up what the mic is reading at a base level, the gain is what affects that).
I hate to be a burden, but could someone explain to me how to use the noise reduction feature in audacity? I get my noise profile, but don't mess around with the settings because to be honest I don't know much of them
. As such, the noise is gone, until I speak, and then you can hear it moreso because it goes from not being there to being in the background of my voice.
whenever I watch videos of someone using the microphone though, I cannot hear any sort of feedback like this, even when it's obvious that their setup is similar! It's just weird because my very cheap ($40) headset has no feedback like this at all, but sounds pretty darn clearn. it just seems weird that a $180 microphone would.
Should the gain be at around say, 9'o clock on the microphone?
Try about 10 to 15 cm from mouth to mic.Kyler45 wrote:I thought I was pretty close to the mic, but I may be wrong.
The "right" levelKyler45 wrote:What level ideally should my microphone be in recording settings?
It depends entirely on how loud you talk. If you have a quiet voice the mic will need to be turned up pretty high. If you bellow like a fog horn then it will need to be set much lower.
Unfortunately the Yeti does not appear to have a "clip light", so, assuming that you have a "medium volume" voice, try setting it to about 3/4 gain, then adjust the recording level on your computer so that Audacity registers about -6 dB (half track height waveform) and make a test recording. Post a short section of the test recording in WAV format in your reply (see here for instructions: http://forum.audacityteam.org/viewtopic ... 49&t=72887)
Remember to project your voice. Talk as if you are talking to a person, not as if you are talking to a microphone.
