record sounds on computer
cubsterky
Post by cubsterky » Wed Apr 08, 2015 10:50 pm
I want to record sounds on my computer and its only recording using the microphone so its recording the sound of the tv instead of the sounds on my computer.
I have audacity 2.0.3
windows 8.1
Probably the zip installer
my audacity settings for recording are windows directsound and primary sound capture driver and stereo input.
please help
Re: record sounds on computer
Post by kozikowski » Wed Apr 08, 2015 10:58 pm
http://manual.audacityteam.org/o/man/tu ... puter.html
Self-recording is not "natural" and special pathways or drivers are needed.
Post by steve » Wed Apr 08, 2015 10:59 pm
Audacity 2.0.3 is a bit old. The current version is 2.1.0 (available here: http://audacityteam.org/download/)
Try the "WASAPI loopback" method described here: http://manual.audacityteam.org/o/man/tu ... ndows.html
