lost file?
tcseacliff
lost file?
Post by tcseacliff » Tue Mar 24, 2015 1:19 am
I imported an audio into audacity , went through the steps and made my Mp3, after saving it and exporting it, cannot find it ? all I find is the original ? I am on win 8 , and cannot go to the place where audacity shows it is saved? not in music, not in documents , not in downloads, not on /in computer??
Re: lost file?
Post by steve » Tue Mar 24, 2015 1:40 am
What location did you select in the Export dialog screen?
This shows the file being exported into a "Jimi Hendrix" folder:
For more information, see: http://manual.audacityteam.org/o/man/fi ... ialog.html
tcseacliff
Re: lost file?
Post by tcseacliff » Tue Mar 24, 2015 2:10 am
when I click save , audacity says I do not have permission to save there? so they gave me another folder choice, so I used that, but the file is not there? my name is Terrence, so that is the folder name they offered but it is not there? and , I did download the LAME app and all that. only thing I can find is the original I saved in downloads from the email it was in so it showed up in outlook as a download. but the Mp3 I made is nowhere to be found in my Terrence folder or anywhere? audacity has it stored in there temp file.
tcseacliff
Re: lost file?
Post by tcseacliff » Tue Mar 24, 2015 2:37 am
my name is Terrence ,that is the folder it was to go to. audacity did not give me a choice in the matter. they named it and said , "do you want to put it in this"? they rest of the prompt said, I was not allowed to put it where the save button goes to? when I open that folder, the saved Mp3 in not there?
Re: lost file?
Post by steve » Tue Mar 24, 2015 4:45 pm
Try Exporting to the Desktop.
