File quadrupled in size
EnderW
Post by EnderW » Tue Mar 24, 2015 1:19 am
The original sound file was 96MB, but after removing noise and reducing the length 8 minutes, the file, when I exported, became 488MB (exported as .wav). Is there something that I am not getting, or is this normal...
Version 2.0.6
Re: File quadrupled in size
Post by steve » Tue Mar 24, 2015 1:44 am
EnderW wrote:The original sound file was 96MB,
How long was the file? Mono or stereo? What format?
From the size difference, I'm guessing that the original file was a compressed format such as MP3.
EnderW
Post by EnderW » Tue Mar 24, 2015 2:08 am
The orginal format was MP3. I just converted to MP3 after reading you message and the file size is now down to 81MB. Thank you for the response
Post by kozikowski » Tue Mar 24, 2015 5:25 am
Audacity doesn't really edit MP3. It converts to its own internal format and then converts back out to MP3 at the other end. When it does that, the compression sound damage goes up. If all you're going to do is simple chopping and editing, you can get higher quality sound with one of the pure MP3 editors like those in this list (scroll down).
http://wiki.audacityteam.org/wiki/MP3#re-encode
