Error message when starting a recording... [SOLVED]
jdmaximus
Post by jdmaximus » Fri Mar 13, 2015 3:59 am
I recently downloaded Audacity and get this error message and can't record anything: Error while opening sound device. Please check the input device settings and the project sample rate.
I have no idea what this means or how to fix it. I tried uninstalling and reinstalling. No good. I have Windows 7 -- 64 bit. Tried installing both latest software (2.6) and older one (2.5). Same message both times.
Re: Error message when starting a recording...
Post by kozikowski » Fri Mar 13, 2015 5:31 am
jdmaximus
Re: Error message when starting a recording... [SOLVED]
Post by jdmaximus » Sat Mar 14, 2015 2:53 am
Went to the link you provided and followed it the best I could and got it working now.
Thanks a million!
