Unable to edit the audio tracks
TheLion
Post by TheLion » Thu Mar 12, 2015 7:30 am
Hey guys and gals ,
I have 2 audios imported in Audacity by File >> Import >> Audio
But when I select some part of any audio track , editing options , Effects options are disabled http://prntscr.com/6fqyv2
Can anyone tell me what am I doing wrong ? And how would I solve this
Thank you ......
Re: Unable to edit the audio tracks
Post by Gale Andrews » Thu Mar 12, 2015 1:32 pm
Look at the green triangle above the blue waves. That shows you are playing or paused. Press the yellow Stop button. See http://manual.audacityteam.org/o/man/fa ... tml#grayed.
