Hello Auda-Experts ,
I've got 2 audios (http://prntscr.com/6fez1p)
When I click on somewhere in any audio track , both tracks start playing from that time .... It should play only that selected track
Can anyone tell me how do I solve this ?
Thank you .............
Both audios playing even when selected 1 track [SOLVED]
Re: Both audios playing even when selected 1 track
You should use the MUTE and SOLO buttons to the left of the tracks to determine which ones get heard.
Re: Both audios playing even when selected 1 track [SOLVED]
Thanks so much !kozikowski wrote:You should use the MUTE and SOLO buttons to the left of the tracks to determine which ones get heard.
It worked perfectly !!
