Total shambles
Total shambles
I have set up system 2.0.6 for Windows 8. When opening from desk-top I get a full screen - cant reduce it. I press "record" curser flies across screen, no sign of recording. I have rebooted and re-installed but no change. What has happened and how do I restore system please.
Re: Total shambles
Is this the same setup as you were using here: http://forum.audacityteam.org/viewtopic ... 33#p268733
What's changed?
What's changed?
Re: Total shambles
I do not know. I ran the set-up from the disc 1.3. x beta (old format). I updated via help page then tried to record but no indication of recording. Cursor races along clocking up hours. I cant see any reset facility or delete recording in any menu bar and hoped uninstall would have cleared it.
Re: Total shambles
We don't make Audacity on a disk, just the downloadable version., but also 1.3.x beta is not version 2.0.6sharpdick wrote:I ran the set-up from the disc 1.3. x beta (old format).
Audacity 2.0.6 can be downloaded here: http://audacityteam.org/download/windows
Uninstall any old versions of Audacity, then download the "installer (exe)" version from the above link.
When installing Audacity 2.0.6, look for the option to reset preferences, and select (enable) that option.
When you first start Audacity 2.0.6, confirm that you wish to reset preferences.
If you are recording from a USB turntable, ensure that the turntable is connected to the computer and turned on before you launch Audacity.
Re: Total shambles
Sorry to be a total pain, but have followed your instructions - uninstalled - installed via link but nowhere was there an invitation to reset preferences. Clicked finish and back to full screen and problem as reported. I cannot get rid of this screen.
Re: Total shambles
If you run the "Recommended Installer" Audacity 2.0.6 installer (.exe file, 22.9 MB, including help files), then there IS an option to reset preferences. Try it again and carefully read each screen during the installation process.
Ensure that you have removed all previous versions of Audacity before you run the installer.
- Quality Assurance
Re: Total shambles
No-one here knows what you mean. Please attach an image of the full screen. Please see here for how to attach files: http://forum.audacityteam.org/viewtopic ... 49&t=64936.sharpdick wrote:Clicked finish and back to full screen and problem as reported. I cannot get rid of this screen.
