Hi,
My system: I am running on Windows 7.
My use of Audacity: I record several vinyls to Audacity projects ".aup." So I have a ".aup" project for each vinyl.
My problem: I would like to apply effects (volume + MP3 export) on each of these project ".aup"
My tests: I wanted to test "mod-script-pipe" but I have not found a version of Audacity with this pre-compiled module.
I tried to compile with Visual Studio 2012, but without success.
My request: Are there any solutions? A batch mode? Does "mod-script-pipe" can do the trick?
If yes, could you send me a version of Audacity with pre-compiled mod-script-pipe. So I can use it directly.
Thank you in advance for your answer.
Best Regards.
