I have a very annoying buzz that I can't seem to eliminate or reduce. I have attached it. Please listen and give me your opinion. I am using a headset plugged into a pc.
Thanks.
Need help with buzz
johnhorning
Need help with buzz
- Attachments
- buzz.wav
- (242.27 KiB) Downloaded 25 times
Re: Need help with buzz
Describe the headset in detail. Model numbers, makers, connection type.
It's one of these, right? Analog headset?
http://www.kozco.com/tech/audacity/pix/PCHeadset.jpg
Most of the buzz is power related. You're in the US? There is a big 60Hz (barely audible) and then every multiple and harmonic up. There is a big one at 420. 440 is the oboe A at the beginning of the orchestra.
That's why you can't get rid of it without trashing the show. No, It's totally not supposed to do that.
When you do post a sample like that, also include a normal volume voice or sound sample. You can post 10 seconds of mono on the forum. You can make any microphone sound like garbage if you turn it up enough.
