GSnap vst plugin is not shown in effects [SOLVED]
Hello
I heard a lot about Audacity and its an awesome program
I downloaded the last version 2.0.6 but I get a problem in installing gsnap plugin
I download the plugin ... copy the dll to the plugins folder in audacity program files ... then i checked "Rescan VST effects next time Audacity is started" ... so I restarted Audacity and the plugin installing window appear ... I checked gsnap plugin and its installed ... but I cant find it in the effect ... what is the problem ? and how to solve it ?
please reply
please reply
Re: GSnap vst plugin is not shown in effects
Have you scrolled down the Effect menu far enough? Plugins are listed below the dividing line (built-in effects are above the dividing line).
thank you for reply ..... I scrolled down many times ... I tried everything ... I looked many times ... but the plugin is not with the effects ..... I redownload the plugin ... I tried other version of Audacity ..... but I cant see that plugin ... is there any solution ??? please ... Im waiting for reply
- Quality Assurance
mr gale ... thank you foe reply ... but I tkink that I told you that I tried EVERYTHING ... and I have a good informations so I know about 32 and 64 bit ...... the plugin is working on others computers (I saw videos on youtube) but on my computer .......... the plugin is not shown in the effects ... its installed ... but not shown ... please raply ... I need a solution
Which version of Windows are you using?
- Quality Assurance
GSnap 32-bit appears in Audacity in our computers too.
Search your computer for GSnap.dll. Delete all copies of it, except the 32-bit version extracted from the ZIP file in the link I gave.
thank you for reply ... Mr Steve ... im using windows xp sp2 ... Mr gale ... I tried that before but it didnt solve the problem
- Quality Assurance
Is that Windows XP 64-bit SP2? If that is 32-bit SP2 you will need SP3 for the next 2.1.0 version of Audacity, and you should get SP3 for the extra security in any case. You are at some risk now that Microsoft does not provide security patches for XP.Maxios7 wrote:thank you for reply ... Mr Steve ... im using windows xp sp2 ... Mr gale ... I tried that before but it didnt solve the problem
Did you try resetting Audacity Preferences? See http://manual.audacityteam.org/o/man/fa ... html#reset. Also (with Audacity closed), delete Documents and Settings<your user name>Application DataAudacityplugins.cfg.
Is GSnap is compatible with XP SP2?
The oldest version of Windows that I have tried it on was XP SP3.
XP SP2 became obsolete on 13th July 2010
https://support.microsoft.com/lifecycle ... gb&c2=1173
