Crash during export multiple
jwatterworth
Post by jwatterworth » Sun Feb 15, 2015 3:47 am
I recorded an LP, the "search for silences" then try to export to I Tunes. I did as AAC files. I am trying to use 2.0.6 version. :?
Re: Crash during export multiple
Post by kozikowski » Sun Feb 15, 2015 4:04 am
Apple (upper left) > About This Mac. Are you using Version 10.9.5?
jwatterworth
Post by jwatterworth » Sun Feb 15, 2015 1:59 pm
Windows 7 PC
Post by Gale Andrews » Sun Feb 15, 2015 2:44 pm
jwatterworth wrote:I recorded an LP, the "search for silences" then try to export to I Tunes. I did as AAC files. I am trying to use 2.0.6 version. :?
What crashes, Audacity or the computer? If the computer crashes, please see http://manual.audacityteam.org/o/man/fa ... tml#reboot.
Are you using Analyze > Silence Finder... before Export Multiple, or something else?
What happens if you Export Multiple as WAV? You can convert WAV to AAC in iTunes: http://manual.audacityteam.org/o/man/tu ... conversion.
jwatterworth
Post by jwatterworth » Sun Feb 15, 2015 9:44 pm
Thanks Gale. I was able to do it as wave and then to AAC in Itunes. Cool!
Post by Gale Andrews » Sun Feb 15, 2015 10:54 pm
jwatterworth wrote:Thanks Gale. I was able to do it as wave and then to AAC in Itunes. Cool!
If you try AAC again, make sure you have FFmpeg from here http://manual.audacityteam.org/o/man/fa ... tml#ffdown.
