Hey all,
Just installed 2.06.
Mostly intuitive, but both my stereo tracks are playing in both ears.
Pretty sure it is stereo...If I swing the marker to L I hear one track (in both ears), to R I hear the other track (in both ears). But in the middle, I hear both tracks in both ears, not one track in each ear.
I am a newb...is this a Windows setting? My cheap earbuds? An Audacity setting?
Thanks for any help!
Stereo is mono
RandomGrin
Re: Stereo is mono
Two-track mono. Same thing on both sides. You can use the magnifier tools to blow up the blue waves so you can see the individual up and down motion. Stereo usually doesn't match. Mono always does.
What are you recording? Which Windows?
- Quality Assurance
Re: Stereo is mono
Double check that at Help > About Audacity... (see the pink panel at the top of the page). If it says 2.06 we did not make it. It should be 2.0.6. Say the version of Windows too.RandomGrin wrote:Just installed 2.06.
If you are using a USB cassette deck or USB turntable, this is probably the issue: http://manual.audacityteam.org/o/man/fa ... #rinstereo.RandomGrin wrote:Mostly intuitive, but both my stereo tracks are playing in both ears.
