Hi, I have windows vista. I have Audacity 2.0.3 but no recording. The blu line is always flat and no sounds from the speakera.
Can you help me? thank you!
no recordin
Re: no recordin
The current version of Audacity is 2.0.6 and is available here: http://audacityteam.org/download/windows
Ensure that the device that you want to record from is enabled and the recording volume turned up in the Windows Sound Control Panel.
Ensure that the device that you want to record from is selected in the device toolbar.
Re: no recordin
Thank you! now it works!!
