No ASIO support?
ibanez0r
No ASIO support?
Post by ibanez0r » Sat Feb 14, 2015 12:10 pm
I must be stupid i cant seem to activate ASIO as the audio host am i doing something wrong?
Audacity v2.06, ASIO4ALL v2.12
Help Please! Any assistance would be greatly appreciated, as windows audio is just not usable to record with there's 2 seconds of lag!
Kind Regards
Re: No ASIO support?
Post by steve » Sat Feb 14, 2015 12:25 pm
ASIO is not enabled in official release builds due to licensing reasons (see: http://wiki.audacityteam.org/wiki/Featu ... strictions)
What are you trying to record?
What equipment are you using?
Which version of Audacity? (see pink text box above)
Which version of Windows?
ibanez0r
Post by ibanez0r » Sat Feb 14, 2015 1:22 pm
Hi steve I wasn't aware of the restrictions :(
Thanks for the info, I was trying to do some multi-track recording, ie, playing audio in track one then recording in track two.
Kind Regards
Post by Gale Andrews » Sat Feb 14, 2015 1:33 pm
ibanez0r wrote:I was trying to do some multi-track recording, ie, playing audio in track one then recording in track two.
You can fix recording latency after the recording by doing latency correction.
To fix playthrough latency, monitor in hardware. Either unmute the input in the playback side of the sound card or in the playback side of the Windows sound control panels (usually not possible on modern computers) or buy a USB interface or USB microphone that lets you monitor in the headphones input of the device.
If you need more help, please state what version of Windows, what version of Audacity and make and model numbers of your recording equipment. See the pink panel at the top of the page.
Post by kozikowski » Mon Feb 16, 2015 1:51 am
Part of the overdubbing tutorial has three certified hardware devices that will allow perfect overdubbing—a live, theatrically correct headphone feed of your overdubbing session. They all make you listen to the device, not the computer.
http://manual.audacityteam.org/o/man/tu ... rdubs.html
