Sorry to bother you again but you were so helpful last time ...
How do I make a hot key for the "Silence Audio" function? I've gotten pretty good at optimizing all the CTRL key bindings that I use with my left hand (THANK YOU the -10db amplification function is a godsend) but I can't figure out how to get the Silence Audio function on a key as it is not an "Effect." Any ideas?
Best regards,
Bill Frezza
Host (and editor) RealClear Radio Hour
Silence Audio hot key?
BillFrezza
- Operating System: Windows 7
Re: Silence Audio hot key?
It has a keyboard shortcut by default: CTRL+LBillFrezza wrote:How do I make a hot key for the "Silence Audio" function?
There is a list of all standard keyboard shortcuts in the manual: http://manual.audacityteam.org/o/man/ke ... rence.html
BillFrezza
D'oh! I missed it.
Thanks.
Thanks.
