Recording with Windows Wasapi
chris319
Re: Recording with Windows Wasapi
Post by chris319 » Fri Feb 13, 2015 5:10 pm
I have GoldWave v6.10. It requires 64-bit Windows. The options are DirectSound or WASAPI.
These pages explain blocking and callback in PortAudio:
http://portaudio.com/docs/v19-doxydocs/ ... lback.html
http://portaudio.com/docs/v19-doxydocs/ ... write.html
Leland
Developer
Post by Leland » Sat Feb 14, 2015 8:13 pm
chris319 wrote:One clue: my program uses PortAudio's callback mode. Does Audacity use PortAudio's callback mode or "blocking" mode?
Audacity uses callback mode.
Leland
chris319
Post by chris319 » Sun Feb 15, 2015 6:42 am
For testing purposes, it might be useful to install Virtual Audio Cable and have two instances of Audacity, one playing back into Virtual Audio Cable and the other recording the output of Virtual Audio Cable. V.A.C. is fairly dependable and this might eliminate some of the vagaries of dealing with hardware drivers. V.A.C. will show up as a WASAPI audio device.
A free trial version of V.A.C. is available: http://software.muzychenko.net/eng/vac.htm
Post by Gale Andrews » Sun Feb 15, 2015 2:08 pm
chris319 wrote:For testing purposes, it might be useful to instal Virtual Audio Cable and have two instances of Audacity, one playing back into Virtual Audio Cable and the other recording the output of Virtual Audio Cable. V.A.C. is fairly dependable and this might eliminate some of the vagaries of dealing with hardware drivers. V.A.C. will show up as a WASAPI audio device.
Well, except that Audacity is designed not to run two instances together on the same computer, so you'd have to set up a workaround to that first.
chris319
Post by chris319 » Sun Feb 15, 2015 9:29 pm
Not worth the bother.
Still, Virtual Audio Cable is a wonderful program and I find it quite useful.
