Files Not Opening
sophie tucker
Files Not Opening
Post by sophie tucker » Fri Feb 06, 2015 10:02 pm
hey, first time poster and audacity newbie. howdy.
i worked on some files w/ Audacity, and saved them 2 ways, as an au file and as a wav. i am trying to open them today w/ no success.
"Error opening file. Could not open file." i've tried dragging the icons, and tried going to File>Open> etc. i am baffled. any ideas? ty!
sophie
WVista, Audacity 2.0.5
Re: Files Not Opening
Post by kozikowski » Fri Feb 06, 2015 10:31 pm
File > Import should open the WAV sound files.
Double click on the AUP Project Manager file associated with your show and it will go find the associated _DATA folder and open the show that way. The AUP file and the _DATA folder have to be in the same location or folder.
sophie tucker
Post by sophie tucker » Sat Feb 07, 2015 1:17 am
ty! i'll do this and get back to ya! :)
