Joining several mp3 files into one file
Irene Rankin
I can't find this information anywhere, or maybe I just don't understand it because I'm very new at this. I have several mp3 files that I'd like to make into one file. I probably have to make them into wav files first, but I don't know what to do after that. Please give very simple directions. Thank you very much.
Re: Joining several mp3 files into one file
Audacity will do that automatically.I probably have to make them into wav files first,
And that's the first problem. If you plan on making a new MP3, you might not want to use Audacity. Every time Audacity makes a new MP3, the sound quality goes down a little bit. If the original sound clips were highly compressed, the sound quality hit might be serious.
But assuming you're good with that, File > Import your clips one right after the other, or Shift-Click all of them (if you can).
They will appear one above the other and play at the same time.
Select all of the tracks by shift-clicking just above each MUTE button.
Tracks > Align Tracks > ...End To End.
They should "shift over" and play as one continuous piece.
File > Export. Audacity will not Save a sound file. You have to Export to get one.
Irene Rankin
Thank you very much. I don't want to make an mp3 file. I'll be very happy with wav.
Note that making a WAV doesn't clear up all the MP3 damage up 'til then. It just prevents the sound quality from getting worse.
You can use Edit > Select > All instead of clicking on each track to select it.
