Still won't record
inhollywood
Still won't record
Post by inhollywood » Fri Feb 06, 2015 1:56 am
I have windows 7 , I downloaded audacity 2.0.6 plus I downloaded LAME v3.99.3 , I try to record music online and it doesn't record, just a straight blue line, i have tried different combinations of settings MME/Speakers/Microphoine etc. and still won't record, why can't I record?
Re: Still won't record
Post by kozikowski » Fri Feb 06, 2015 2:01 am
The Lame software is to allow Audacity to make a new MP3. That's all it does.
I'm not the Windows elf. This is the document on self-recording
http://manual.audacityteam.org/o/man/tu ... puter.html
http://manual.audacityteam.org/o/man/tu ... ndows.html
