NOT RECORDING!
lovespotter
NOT RECORDING!
Post by lovespotter » Fri Feb 06, 2015 12:36 am
Why is it whenever I record something the lines will move up and down but bceome straight after six seconds and move up and down the next six second and repeat the same thing over again. Whenever I record for just 3 second, the lines movi up and down but I press stop to stop the recording and edit it everything become straight! Please help! I uninstalled it and installed it again many time but the same problem keeps on happening.
Re: NOT RECORDING!
Post by kozikowski » Fri Feb 06, 2015 1:14 am
We can't see your computer, so you need to tell us a lot more about what you're doing. Start with the information in that pink band at the top of the page.
http://www.kozco.com/tech/audacity/Docu ... tions3.pdf
Re: NOT RECORDING!
Post by Gale Andrews » Fri Feb 06, 2015 3:38 pm
lovespotter wrote:Why is it whenever I record something the lines will move up and down but bceome straight after six seconds and move up and down the next six second and repeat the same thing over again. Whenever I record for just 3 second, the lines movi up and down but I press stop to stop the recording and edit it everything become straight!
Almost certainly because Audacity can't write to the temporary directory you specified at Edit > Preferences... (Directories section). Look in there and choose a drive that has at least 100 GB of space and choose a folder on that drive that you have permission to write to. If you are not logged in as an administrator you cannot write to Program Files or to someone else's user space.
lovespotter wrote:I uninstalled it and installed it again many time but the same problem keeps on happening.
Reinstalling should set your temporary directory to a location you can write to, but only if you enable the "Reset Preferences" box half way through the installer. Say "Yes" when you launch Audacity after reinstallation and it asks if you want to reset Preferences.
