Phasing
Re: Phasing
Please give the information requested in the pink panel above.
What equipment are you using?
How do you have it set up?
What settings are you using?
What is selected in the device toolbar?
Re: Phasing
It might be Windows Enhanced Services.
http://manual.audacityteam.org/o/man/fa ... hancements
Enhanced Services Hates music.
Re: Phasing
Using version 2.0.6 I think it was .exe on Vista
Re: Phasing
I've tried all the settings on the device bar to no effect.
Re: Phasing
It's not in the Device Toolbar. You have to go into Windows Control Panels to check and set this. That link tells you how.
