I'm creating a selection of portions of tunes, usually about 35 seconds long for a pub music quiz I'm running. The objective is to guess the title and the artist. Using Audacity this is not a problem to edit relevant tunes down to the required size. However, some songs use the Title words quite early on. Is there a way to remove/obscure the title only in this situation?
Thanks,
Music Quiz
Re: Music Quiz
You mean stop the singer from singing the words? You can beep them out. Drag-select the words and Generate > Tone: 400Hz or 300Hz at 0.2 size. That will stop the music, too. We can't easily split the singer from the music.
Re: Music Quiz
Try applying this "reverso" effect to the section containing the words.
It takes short sections of the sound and reverses them.
http://forum.audacityteam.org/viewtopic ... 65#p160165
Instructions for installing the effect: http://wiki.audacityteam.org/wiki/Downl ... g_Plug-ins
Re: Music Quiz
Thanks a lot, folks. I'll try to select songs that don't use titles too early in future, I think
Plus I'll give those options a try as well
Cheers
Cheers
