Effects List Scroll
bullet399
Effects List Scroll
Post by bullet399 » Mon Jan 26, 2015 12:07 am
Is there a way to scroll the effects list with my mouse wheel on the Windows version of Audacity?
It works on my mac with no problem but not at all on Windows.
Thanks for your time.
Windows 7 Pro 64-bit
Audacity 2.0.6 executable
Re: Effects List Scroll
Post by steve » Mon Jan 26, 2015 12:16 am
On Windows you can type the first letter of the effect that you want and the list will scroll down to the first effect that begins with that letter. Repeated presses of that key will scroll to the next effect that begins with that letter.
