I am new to 2.0.06. After making new tracks etc., when I make a mistake and clk on the Undo icon nothing happens. Why?
Also, how do I undo a track than I do not want?
Undo won't work
Re: Undo won't work
Most tools only work from Stop. If you try it from Pause, it may not work.
- Quality Assurance
Re: Undo won't work
You can remove a track using the [X] button top left of the track.Allanx wrote:how do I undo a track than I do not want?
