Controls Grayed Out - Program Lock [SOLVED]
IMRogers
Post by IMRogers » Fri Jan 23, 2015 9:18 pm
Windows Vista Service Pack 2 (32-bit)
Audacity v. 2.0.6
.exe installer
Hello,
Came back to Audacity today after six months or so of not using it on this computer and found that each time I try to edit a file, I can playback the sound fine but the editing controls lock up and are displayed all in gray on the menus. Sometimes I can perform a few editing tasks before the menus gray out, and other times they gray out immediately after the file opens. I uninstalled my previous version and installed 2.0.6, but the same problem keeps happening with both. I also tried downloading the LAME encoder and FFmpeg libraries (also for v. 2.0.6) but didn't notice a change.
Files more than 20 minutes long will also open very slowly, and the sound wave takes a while to appear in the project editing screen, sometimes accompanied by the "Not Responding" message from Windows before the file successfully opens.
Any help is much appreciated!
Code: Select all
2:59:34 PM: Audacity 2.0.6
2:59:34 PM: Trying to load FFmpeg libraries...
2:59:34 PM: Trying to load FFmpeg libraries from default path, 'C:Program FilesFFmpeg for Audacityavformat-55.dll'.
2:59:34 PM: Looking up PATH environment variable...
2:59:34 PM: PATH = 'C:Windowssystem32;C:Windows;C:WindowsSystem32Wbem;C:PROGRA~1COMMON~1ULEADS~1MPEG;C:WindowsSystem32WindowsPowerShellv1.0;C:Program FilesQuickTimeQTSystem'
2:59:34 PM: Checking that 'C:Program FilesFFmpeg for Audacity' is in PATH...
2:59:34 PM: Warning: FFmpeg directory 'C:Program FilesFFmpeg for Audacity' is not in PATH.
2:59:34 PM: Temporarily appending ';C:Program FilesFFmpeg for Audacity' to PATH...
2:59:34 PM: Checking for monolithic avformat from 'C:Program FilesFFmpeg for Audacityavformat-55.dll'.
2:59:34 PM: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 127: the specified procedure could not be found.)
2:59:34 PM: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 127: the specified procedure could not be found.)
2:59:34 PM: avformat not monolithic
2:59:34 PM: Loading avutil from 'avutil-52.dll'.
2:59:34 PM: Loading avcodec from 'avcodec-55.dll'.
2:59:34 PM: Loading avformat from 'C:Program FilesFFmpeg for Audacityavformat-55.dll'.
2:59:34 PM: Returning PATH to previous setting...
2:59:34 PM: Actual avutil path C:Program FilesFFmpeg for Audacityavutil-52.dll
2:59:34 PM: Actual avcodec path C:Program FilesFFmpeg for Audacityavcodec-55.dll
2:59:34 PM: Actual avformat path C:Program FilesFFmpeg for Audacityavformat-55.dll
2:59:34 PM: Importing symbols...
2:59:34 PM: All symbols loaded successfully. Initializing the library.
2:59:34 PM: Retrieving FFmpeg library version numbers:
2:59:34 PM:    AVCodec version 0x373466 - 55.52.102 (built against 0x373466 - 55.52.102)
2:59:34 PM:    AVFormat version 0x372164 - 55.33.100 (built against 0x372164 - 55.33.100)
2:59:34 PM:    AVUtil version 0x344264 - 52.66.100 (built against 0x344264 - 52.66.100)
2:59:34 PM: FFmpeg libraries loaded successfully.
2:59:39 PM: File name is C:UsersAfternoon MenPodcast Editing2013.11.1 Jason and MartyJason Hertz.MP3
2:59:39 PM: Mime type is *
2:59:39 PM: Opening with libsndfile
2:59:39 PM: Opening with libmad
2:59:39 PM: Open(C:UsersAfternoon MenPodcast Editing2013.11.1 Jason and MartyJason Hertz.MP3) succeeded
Re: Controls Grayed Out - Program Lock
Post by kozikowski » Sat Jan 24, 2015 1:26 am
Are you filling up your hard drive? Does somebody use this machine while you're not?
When Audacity starts editing a file, it has to break free a lot of drive space for effects processing and UNDO. If it can't do that, it may hang in random places like what you have.
Post by Gale Andrews » Sat Jan 24, 2015 7:37 pm
IMRogers wrote:Came back to Audacity today after six months or so of not using it on this computer and found that each time I try to edit a file, I can playback the sound fine but the editing controls lock up and are displayed all in gray on the menus.
Might this be the problem - you need to press the yellow Stop button http://manual.audacityteam.org/o/man/fa ... tml#grayed ?
IMRogers
Re: Controls Grayed Out - Program Lock [SOLVED]
Post by IMRogers » Sun Jan 25, 2015 7:27 pm
Wow, this wasn't as simple as turning it off and on again, but was pretty close. Pressing Stop did the trick - thanks for the quick response!
