Warning - Opening old project file
anthonyl
Post by anthonyl » Fri Jan 23, 2015 8:54 pm
XP SP3 Audacity 2.0.6
2.0.6 is working fine for new project but I went back to work on something from 2011 and get the "Warning - Opening old project file" window saying that the format has changed from 1.2.6 and that it likely won't work (and it doesn't).
So what do I do? Reinstall the old version? Have both versions running? Is there a "convert" routine.
I'm not a heavy or frequent user and I've searched for the subject message but must have missed the obvious.
Thanks
Re: Warning - Opening old project file
Post by steve » Sat Jan 24, 2015 2:03 am
anthonyl wrote:"Warning - Opening old project file" window saying that the format has changed from 1.2.6 and that it likely won't work (and it doesn't).
I don't recognise that warning message. Could you quote the warning word for word?
anthonyl
Post by anthonyl » Sat Jan 24, 2015 9:34 am
This is the message:
Warning Message
and if I continue to open the project this is the result:
Old project opened
I've got stacks of old projects on my "to do" list but surely this must have been a common issue?
Post by steve » Sat Jan 24, 2015 2:22 pm
anthonyl wrote:and if I continue to open the project this is the result:
Audacity 2.0.6 has opened the project correctly.
That image shows that the audio in the project is hitting 0 dB and so will probably be distorted.
You can turn off the red "clip indicators" in the View menu. See: http://manual.audacityteam.org/o/man/vi ... w_clipping
Post by Gale Andrews » Sat Jan 24, 2015 6:10 pm
Also, please be careful with Windows XP. Microsoft are no longer officially supporting it, so it will be unpatched against any new security vulnerabilities that appear.
Ensure you have a good third-party anti-virus application. Be aware though that this will not give you complete protection against a previously unknown attack.
For some extra protection you can install http://technet.microsoft.com/en-us/security/jj653751 .
If it is not practicable for you to update to the much more secure Windows 7 or Windows 8, you can consider installing a Linux operating system instead. Most versions are free and all are very secure.
anthonyl
Post by anthonyl » Sat Jan 24, 2015 10:52 pm
Yes I thought the distortion was due to the new version.
steve wrote: You can turn off the red "clip indicators" in the View menu. See: http://manual.audacityteam.org/o/man/vi ... w_clipping
Thanks and my apologies. I've now (after backing up) opened a couple of other older projects and though I obviously get the warning they are fine. Yes I know about the clipping and I'm astounded that I over cooked that project which was the first old one that I looked at with the new version and hence my panic.
Post by steve » Sun Jan 25, 2015 4:22 pm
anthonyl wrote:Yes I thought the distortion was due to the new version.
No, that will have been in the original project.
anthonyl wrote: I'm astounded that I over cooked that project
Easily done.
If you keep the tracks as 32 bit float format, then if over 0 dB is caused by processing, it can be corrected by amplifying (either the Amplify or Normalize effects) back down below 0 dB. You can't do that with 16 bit or 24 bit tracks because those formats do not support over 0 dB.
anthonyl
Post by anthonyl » Sun Jan 25, 2015 10:54 pm
Easily done.
That's useful to know (I think). I'm not sure what you mean by 'caused by processing'.
Most recording are for a specific purpose using a mic and we know the settings needed but every now and again I'll pick something up from an internet source or from my stereo system and I think if the internet source is live there is little opportunity to get levels right as they change from music to speech etc so the 32 bit float flexibility will be helpful. For the others there is usually opportunity to do a level test beforehand to ensure that peaking doesn't occur.
Are there any downsides to using the 32 bit float format?
anthonyl
Post by anthonyl » Sun Jan 25, 2015 11:02 pm
Gale Andrews wrote:Also, please be careful with Windows XP. Microsoft are no longer officially supporting it, so it will be unpatched against any new security vulnerabilities that appear.
Eh eh. Well here isn't the right place to get involved in a long discussion but XP has been insecure since its release and in nearly 15 yrs they still didn't fix it so I've used an insecure OS for all that time. I do have other layers of protection and EMET looks interesting though the full Framework requirement is somewhat off-putting. I'm hoping to hang on to this machine until I go Windows 10 (I've always trust the odd numbers and it really is 9).
Post by steve » Mon Jan 26, 2015 12:51 am
anthonyl wrote:That's useful to know (I think). I'm not sure what you mean by 'caused by processing'.
If you set your recording levels too high and the recording is clipped (distorted), then that is permanent - time to reshoot.
If you have a good, non-distorted recording and you apply an effect that results in the waveform getting bigger vertically to the extent that it smashes into the top/bottom of the track, then:
a) If the track is 16 bit or 24 bit, (see the info panel on the left end of the track), then the damage is permanent - time to reshoot.
b) If the track is 32 bit float, then the waveform itself is not damaged - it will still distort if you play it, but it is recoverable - all you need to do is to amplify ("Amplify" or "Normalize" effects) to below 0 dB, then it will be good as new.
Demonstration:
1) Generate a tone (Generate menu)
2) Ensure that the track is 32 bit float. If not, convert it to 32 bit float (see "Sample format": http://manual.audacityteam.org/o/man/tr ... tml#format)
3) Apply the Amplify effect, enable the "allow clipping" option and set the "New peak amplitude" to 10 dB.
Note that playing the tone will be very loud and distorted.
4) Apply the Amplify effect and set the "New peak amplitude" to -3 dB (minus three).
Note that the waveform is a nice smooth sine wave and will play as a clear undistorted tone.
Repeat the above but in step 2 set the track sample format to 16 bit.
Note that after step 4, the waveform has the tops and bottoms of the waveform missing and when played sounds very raspy.
The default sample format is set in "Edit menu > Preferences > Quality". That should be set to 32 bit float.
