The effect Sliding Time Scale / Pitch Shift
юра00
Post by юра00 » Tue Jan 20, 2015 12:45 pm
Each time the effect overthows settings to defaults (0). It is uncomfortably, please, correct so, that last values used should have been remembered, such as Change speed, Change pitch... Why does the effect (Sliding Time Scale / Pitch Shift) work so slowly? See one of my previous topic, where the similar problem has been discussed and solved.
http://forum.audacityteam.org/viewtopic ... 46&t=81848
Please, take a view of the effect in the head of the regular topic.
Re: The effect Sliding Time Scale / Pitch Shift
Post by Gale Andrews » Tue Jan 20, 2015 6:04 pm
Not all built-in effects yet save their settings after the Audacity session. Change Speed is one effect that does. No Nyquist effects yet save their settings after the Audacity session, although you can change their default settings by editing their NY file.
We will look at saving settings for built-in effects when they are converted to the same "real time preview" interface that you see in 2.1.0-alpha for VST and LADSPA effects.
Sliding Time Scale is a very high quality algorithm in comparison to Change Pitch and Change Tempo, so it is slower (as the Manual states) http://manual.audacityteam.org/o/man/sl ... shift.html.
юра00
Post by юра00 » Tue Jan 20, 2015 7:54 pm
Thank you! But now this effect neither saves last values, nor allows to install appropriate defaults. Each time installed "0" is seen - no effect and you should set figures again. It occupies 5 min (!) for processing 3.5 min track - so long?
Post by Gale Andrews » Tue Jan 20, 2015 8:03 pm
юра00 wrote:Thank you! But now this effect neither saves last values
The last values are available until you close the session.
юра00 wrote:nor allows to install appropriate defaults.
If you search for "GPrefs" in srceffectsChangeSpeed.cpp it should not be too hard to see how to write the plugin settings to audacity.cfg. When you have made the changes, recompile Audacity.
But as I said, these methods of saving settings are likely to change in the not too distant future.
