export as wav (or mp3) has no sound [SOLVED]
boardwalk
Post by boardwalk » Sun Jan 18, 2015 8:41 pm
Hello,
After some searching, I've seen other posts that have been made on this topic over the years, but nothing I found seems to address my problem. I'm trying to take a short wav file and trim it, lower the volume, and export it. When I do, the resulting wav file has no sound.
Things I've read and tried:
- Perhaps your speaker/device volume is turned down. No, I can play the original and other wav files fine. I also hear it fine when playing in Audacity.
- Try loading the resulting wav file back into Audacity and see if there is anything there. Yes, when I do that, it shows the waveform and it plays it just as I expect it to -- at the trimmed length and at the lower volume.
- You need to save the project before exporting the wav file. I don't see why that should affect the exported file, but I tried it, and it made no difference.
- You exported a selection that didn't include the actual sound. No, it's clear that's not the case because I've tried both export and export selection, and in both cases, the actual data is making it to the file because I can open the resulting wav file in Audacity and it is all there.
I also tried exporting a wav file before I make any modifications to it (so it is exactly the same as the original), and that works. I hear it fine when I replay the output file. Once I trim it or something, then the output file has no sound.
I am using VLC to play the various files.
Thanks for your help.
Re: export as wav (or mp3) has no sound
Post by kozikowski » Sun Jan 18, 2015 11:38 pm
Do they all open in Windows Media?
DVDdoug
Forum Crew
Post by DVDdoug » Mon Jan 19, 2015 12:21 am
Weird, man!
So, you've got an audio file... You can open and play it in Audacity, but VLC won't play it...
So, It's supposed to be a "regular" WAV file, but there's something wrong with it or something non-standard about it...
Questions -
What are the format details? (Sample rate, bit-depth, number of channels?) Did you intentionally change any of these things? (The sample rate is shown as "Project Rate" in the lower-left of the Audacity window.)
If you didn't change the format, how does the file size of the exported file compare with the files size of the original? i.e. If you trimmed-off a little bit, is the new file slightly smaller? If you trim-off half of it, is it half the size?
What's the playing-time and what's the file size of the "bad" file?
Can you give us the exact steps and the exact options you use when you export?
Post by kozikowski » Mon Jan 19, 2015 12:46 am
Create a 3 to 5 second mono sound file that exhibits this behavior and post it here.
http://forum.audacityteam.org/viewtopic ... 49&t=72887
boardwalk
Post by boardwalk » Mon Jan 19, 2015 1:50 am
kozikowski wrote:Do they all open in Windows Media?
OK. This is strange. I opened it with Windows Media Player, and it showed that the volume was all the way down. So I turn it up, and it plays it. But VLC's volume was up, and it still is and doesn't play it.
Post by steve » Mon Jan 19, 2015 1:59 am
boardwalk wrote:OK. This is strange. I opened it with Windows Media Player, and it showed that the volume was all the way down. So I turn it up, and it plays it. But VLC's volume was up, and it still is and doesn't play it.
So it would seem that the problem is with VLC.
Did you tell us which version of Windows you are using?
Post by kozikowski » Mon Jan 19, 2015 2:00 am
boardwalk
Post by boardwalk » Mon Jan 19, 2015 2:07 am
DVDdoug wrote:Weird, man!
Questions -
Sample rate is 44100, which I didn't change. 32-bit float, which I didn't change. Two channels, which I didn't change.
Yes, I trimmed it to about 1/4 the length, and it went from 28 KB to 7 KB as expected.
Playing time is 0.038 sec (it's just a little click sound). Size is 7 KB. The original is like a mouse "click down" sound followed by the "click up", and I trimmed the "click up" out of it along with the dead space in between.
Exact steps:
FIle > Open. Answer the "Warning" box by saying "Make a copy..."
Drag the selection so it higlights the part I want (from 0.00 to just under 0.04 seconds).
Click the "Trim Audio" button.
Drag the output volume down to 0.3.
Press Play, and it sounds exactly like I want it to.
File > Export..., then save as a new name in "WAV (Microsoft) signed 16 bit PCM" format.
I don't fill in any of the values for the tag fields, and i click OK.
Per my earlier post, the file plays fine in Windows Media Player (after I turned the volume up). Doesn't make a sound when I try playing it in VLC, The original file does play fine in VLC, howver.
That's it. Pretty strange, huh?
boardwalk
Post by boardwalk » Mon Jan 19, 2015 2:11 am
steve wrote:So it would seem that the problem is with VLC.
I suppose, but it's weird that it plays the original and all other wav files no problem. Just not the ones exported by Audacity.
I'm using WIndow 7 Home Premium with Service Pack 1.
boardwalk
Post by boardwalk » Mon Jan 19, 2015 2:14 am
kozikowski wrote:Create a 3 to 5 second mono sound file that exhibits this behavior and post it here.
Working on it. Should original be mono or just change it to mono?
