How to re-master.
How to re-master.
Hello people.. I will be honest in the first instance with you that I am not to clever in understanding how to operate things for medical reasons. Can anyone spare the time to explain to me bit by bit as to what buttons I press (How to operate it) to get some of my wav files to sound like they have been remastered please. I am looking for a more crisp treble and clear but not too heavy bass tones... many thanks for everyone's time on this. Sid Brighton UK.
Re: How to re-master.
Learning how to master music properly takes years of study and experience. It's not something that we can teach you in a few forum exchanges.
The simplest way to adjust the bass and treble is with the "Bass and Treble" effect: http://manual.audacityteam.org/o/man/ba ... reble.html
For more precise control you can use the "Equalization" effect: http://manual.audacityteam.org/o/man/equalization.html
When "mastering", it is important that you can listen to the music through a sound system that accurately reproduces the sound - computer speakers will not give a true representation of the sound. Using reasonable quality headphones is the least expensive way to monitor, though be aware that headphones can often over-emphasize the upper frequencies and make "hiss" far more noticeable than when listening through speakers.
Thank you very much for informing me of an answer Steve.
