Can Audacity identify the "KEY" after transposing?
karenlajoy
I am a newbie can Audicity identify the key after you have changed the pitch thanks Karen
Reason: fix typos in title
Re: Can Audicity identify the "KEY" after transposig?
I presume that you are talking about the key signature of a piece of music. If that is what you are asking, then Audacity is not able to identify the key of a piece of music. There is a plugin available that can identify the pitch of a single note with reasonable accuracy.
karenlajoy
Steve do you know what the plug in is? Many thanks
Re: Can Audacity identify the "KEY" after transposing?
The plugin I was referring to is called "Pitch Detect".
Download it here: http://wiki.audacityteam.org/wiki/Nyqui ... tch_Detect
Instructions for installing: http://wiki.audacityteam.org/wiki/Downl ... ns#install
- Quality Assurance
Also see http://forum.audacityteam.org/viewtopic ... 97#p232797 for a third-party application and online service that can fairly often identify the key signature (tonality).
Training your ear to work out what the tonic note is then using Steve's plugin (or look for the highest peak in Analyze > Plot Spectrum...) is the most reliable method.
karenlajoy
Many thanks. Karen
