Installation Problem [SOLVED]
ashpacenter
Post by ashpacenter » Thu Jan 15, 2015 6:26 pm
I attempted multiple times to install Audacity, and nothing happened at all. I tried to double-click on the downloaded exe file. Nothing. I have windows 8.1.
ashpacenter
Re: Installation Problem
Post by ashpacenter » Thu Jan 15, 2015 7:13 pm
I tried with versions 2.0, 2.2 and 2.6.
Post by steve » Thu Jan 15, 2015 7:17 pm
We don't make Audacity with those version numbers. Audacity versions have 3 digits. The current version is 2.0.6 which you can get from here: http://audacityteam.org/download/windows If you got it from somewhere else it may not be genuine Audacity.
The recommended version is the "Audacity 2.0.6 installer (.exe file, 22.9 MB, including help files) for Windows 2000/XP/Vista/Windows 7/Windows 8" at the top of that page.
ashpacenter
Post by ashpacenter » Thu Jan 15, 2015 8:15 pm
Yes, I apologize for leaving out the middle digit. The version I tried were 2.0, 2.0.2, and 2.0.6. Yet nothing worked. Please help.
Post by Gale Andrews » Fri Jan 16, 2015 4:02 pm
ashpacenter wrote:Yes, I apologize for leaving out the middle digit. The version I tried were 2.0, 2.0.2, and 2.0.6. Yet nothing worked. Please help.
You need to download from http://audacityteam.org/download/windows. Click the text links. Do not click on download buttons because they are advertisements for other products.
If your mouse is flaky, try right-click over "audacity-win-2.0.6.exe", and click "Open". If you are not logged in as an administrator, right-click and choose "Run as administrator".
ashpacenter
Re: Installation Problem [SOLVED]
Post by ashpacenter » Fri Jan 16, 2015 4:57 pm
Got it, thank you so much for your help!
(Not sure why it didn't work the earlier times...?)
