Listening to LP through PC without recording
I have an Encore Technologies USB turntable and an Acer ZS600 desktop computer running Win 8.1 Is there amny way I can lesten to an LP through my PC without recording? Thanks so much for any assistance!
Reason: more precise topic title
Re: Listening to LP through PC
Yes, but there is likely to be about 1/2 second delay between sound going into the computer (via USB) and coming out (via your sound card).
Assuming that you have Audacity set up correctly to record from the USB device and play back through your normal sound card (setting are in the device toolbar) then all you need to do is to turn on "Software Playthrough" (near the bottom of the "Transport" menu).
- Quality Assurance
Re: Listening to LP through PC without recording
Moved to the correct Windows board.
If you want to listen without using Audacity, right-click over the speaker icon by the system clock, then choose "Recording Devices". Right-click over the USB Audio Codec for the turntable, then choose "Properties". Then click the "Listen" tab, enable "Listen to this device" and set the playback device to your computer sound device. Then OK and OK.
You will also need to click in the Audacity Recording Meter to "Start monitoring" if you want to listen without actually recording.steve wrote:Assuming that you have Audacity set up correctly to record from the USB device and play back through your normal sound card (setting are in the device toolbar) then all you need to do is to turn on "Software Playthrough" (near the bottom of the "Transport" menu).
Thank you both, so much! Sounds a bit tinny, but I believe that is due to the poor quality stylus. Thanks again!
- Quality Assurance
If you are using external computer speakers or built-in audio speakers it is more likely due to those.mldunlevy wrote:Thank you both, so much! Sounds a bit tinny, but I believe that is due to the poor quality stylus. Thanks again!
