2.0.5 - Very long recording, very choppy.
Jacob843
Post by Jacob843 » Fri Jan 09, 2015 1:01 am
Hello! I am having a bit of trouble. Last night, I setup Audacity to record the radio station in my area. I selected Stereo Mix at my input, ran a few tests, and saw they sounded okay. I went to bed, and went to school the next day. I just ended the recorded about an hour ago. I saved the audacity file. It ended up being about a 20 hour recording.
Now, here is the issue. I went to playback a random bit in the middle, and heard a lot of choppiness. A lot: http://imposinghosting.com/e0022ab0.wav. I quit out of audacity, and reopened my project file, to be greeted with the follow message:
"Project check of 1-7-14_data" folder found 20169 orphan block file(s). These files are unused by this project, but may belong to other projects. They are doing no harm and are small." I selected the "continue without deleting; ignore the extra files this session" option, and my main recording was gone. Ex: http://gyazo.com/ea2593140ebb037c9753a1584b8a0e3a. I checked, and all of the data files are there, but as you can hear above, most are choppy. Choppy in Audacity playback and choppy in exports. However, the earlier files are not choppy. I read that there is some type of technical limits about recording for more than 6 hours, which might be what happened to me.
This audio means a lot to me - I was on it throughout the day. I am willing to try anything to get these files sounding somewhat normal. Any information you need, just ask. I appreciate the help!
Re: 2.0.5 - Very long recording, very choppy.
Post by kozikowski » Fri Jan 09, 2015 3:28 am
Earlier Audacity versions had a 13 hour Project limit assuming Audacity sound defaults. WAV file format has a 4 GB top limit and sometimes as little as 2GB.
Do you leave your computer doing other stuff during the night? Conflicts and filling up the hard drive may be what's causing the damaged sound file snippets.
Fill in the numbers from the pink band at the top of this message.
I got burned with the Audacity Timer tool when I accidentally made the times of day "pass" each other. Start 14:45:50 Stop 14:45:47. I quickly corrected my error and didn't see that Audacity automatically rolled to the next Day in order to accommodate the times — and didn't roll back.
Of such things are 20 hour recordings made.
Post by kozikowski » Fri Jan 09, 2015 3:36 am
I don't see anybody recovering that. We'll see what the other elves have to say.
Jacob843
Post by Jacob843 » Fri Jan 09, 2015 7:05 pm
Hi koz. The computer was left running all night, as usual. It had about 24GB of RAM free, and the CPU load was averaging 12%. You can see my specs here: http://jacobhartmann.me/specs.txt
The drive I was recording to was connected SATA III, with 1.5TB free.
What do you mean to fill in the numbers? Are you referring to the "This forum is for Audacity 2.x on Windows."?
If so, I am running Windows 7 Ultimate, Service Pack 1. My audacity version is 2.0.5, installed through the exe (from my memory).
Thanks!
Post by Gale Andrews » Fri Jan 09, 2015 7:17 pm
Jacob843 wrote:I saved the audacity file. It ended up being about a 20 hour recording.
Then almost certainly you are using Audacity 2.0.5 or earlier and have been hit by the bug that you cannot reopen projects containing audio over a certain length - the length limit is shorter the higher the project rate is. See http://wiki.audacityteam.org/wiki/Relea ... e_Projects.
To open the project, try 2.0.6: http://audacityteam.org/download/windows.
Even if you the project reopens as recorded, you can't fix the problem once it's recorded like that.
What project rate were you recording at (see bottom left)? 44100 Hz or 48000 Hz is good. Higher rates put the computer under increasing strain (because of the increasing amount of data being transported/read/written), without there being a significant audible increase in quality even if it records correctly.
Jacob843
Post by Jacob843 » Fri Jan 09, 2015 7:19 pm
I tried in 2.0.6, but I am still get the orphan warning, so I guess that is still a no-go. I was recording at 44100 Hz.
Post by Gale Andrews » Sat Jan 10, 2015 2:46 pm
Jacob843 wrote:I tried in 2.0.6, but I am still get the orphan warning, so I guess that is still a no-go. I was recording at 44100 Hz.
Are you sure you quit 2.0.5? If you launch 2.0.6 with 2.0.5 still running, you will only get a new project window in 2.0.5.
Otherwise if there is enough good audio in the project, you could try http://manual.audacityteam.org/o/man/re ... ually.html. This involves sorting the AU files by time, then renaming the files so they have a consistent naming sequence.
You should have a load of "d" folders in the "e00" folder inside the _data folder for the project. The best way is probably to make a new folder, then empty the contents of "d00", "d01", "d02" and "d03" into the new folder. Then as described in the link, do the sort and rename of the AU files and run the 1.2 Recovery Utility on those files to make a mono or stereo WAV file. Then repeat for the subsequent "d" folders.
Jacob843
Post by Jacob843 » Sat Jan 10, 2015 9:34 pm
I did close 2.0.5 before opening 2.0.6.
I have a question about the renaming, though. So I have d00, d0a, d0b, etc.. to d61. So what I need to do, is take all the .au files from those folders, and put it in just one, right? So just getting rid of the sub-folder structure? I just want to ensure I don't mess this up further than it is.
Thank you, and once clarified, I will do the whole rename thing.
Post by Gale Andrews » Sat Jan 10, 2015 11:55 pm
Jacob843 wrote:So I have d00, d0a, d0b, etc.. to d61. So what I need to do, is take all the .au files from those folders, and put it in just one, right? So just getting rid of the sub-folder structure? I just want to ensure I don't mess this up further than it is.
Yes you don't need the subfolder structure of 256 files per subfolder. However the recovery utility tends to choke on more than about 1000 files, so that's why I suggested working on no more than the contents of four subfolders at a time.
You can call the subfolders containing 1024 AU files what you like as long as they have the AU files time sorted and renamed and no subfolders within that. The aim is to generate a WAV file (or two files for stereo) from each subfolder of 1024 files then join the WAV files together.
Note that the d0a folder doesn't come after d00 in time sequence - the sequence goes d00, d01, d02, d03,...d09, d0a, d0b, d0c, d0d, d0e, d0f, d10, d11... and so on. But you should be able to tell that from the timestamps of the AU files.
Jacob843
Post by Jacob843 » Sun Jan 11, 2015 12:33 am
Alright, sounds good. There are just under 25,000 files, so this may take a while. Can I skip ahead to the affected part, or will that mess it up?
