Combining MP3s [SOLVED]
PMD
Post by PMD » Wed Jan 07, 2015 6:24 am
I'm trying to overlay two MP3s so that they play at the same time, not one after the other. Is Audacity able to do that?
Re: Combining MP3s
Post by kozikowski » Wed Jan 07, 2015 6:31 am
Yes. Import one and then import the other. They will arrive one above the other and play at the same time.
You may not, however, export the combined show at the same MP3 quality value as the originals. The filesize is going to get very much larger for the same sound quality.
Never do sound production in MP3. It's a bulldozer. You can dig yourself a hole vey efficiently.
PMD
Re: Combining MP3s
Post by PMD » Wed Jan 07, 2015 6:34 am
kozikowski wrote:Yes. Import one and then import the other. They will arrive one above the other and play at the same time.
I've got them both imported, I just can't do anything with them. I click on "File" and everything, but import and exit are dead.
Re: Combining MP3s
Post by kozikowski » Wed Jan 07, 2015 6:38 am
Many of the Audacity tools drop dead if you are in Pause rather than Stop.
PMD
Re: Combining MP3s
Post by PMD » Wed Jan 07, 2015 6:43 am
kozikowski wrote:Many of the Audacity tools drop dead if you are in Pause rather than Stop.
Ah, just figured that out. Now, it's telling me I need a .dll file to do MP3s. Oh well.
PMD
Re: Combining MP3s [SOLVED]
Post by PMD » Wed Jan 07, 2015 6:54 am
OK, finally got it to do exactly what I wanted. Thanks for your help kozikowski!
