Initial Installation
roadster
Post by roadster » Sun Dec 28, 2014 8:01 pm
On p.17 of the manual it says "If you couldn't find the microphone (USB controller ...)from the Device list, close the S/W and try again. All I can ever get under Recording is "Microphone (Realtek High Def or Microsoft Sound Mapper)
Re: Initial Installation
Post by steve » Sun Dec 28, 2014 8:18 pm
Our manual does not have page numbers, so I don't know what instructions you are referring to. (This is the current online version of the Audacity manual: http://manual.audacityteam.org/o/)
In order for Audacity to be able to "see" an audio device, it must be recognised and enabled in Windows. Check that your USB device is enabled in the Windows Sound Control Panel.
