Recording Problems
ruthiemaykanga
Recording Problems
So I am new to Audacity and am having some issues. My microphone is not being picked up by the program. It was picked up once and I was able to make one recording but then it stopped and now wont pick up any sound. Audacity says that the microphone is usable and is monitoring something that is not my microphone. It is really frustrating and would like some help asap. Thankyou.
Re: Recording Problems
That's a little too fuzzy. USB microphone? What kind? Laptop? Which Windows? Fill in the questions in the pink band above.
- Quality Assurance
Are you selecting the microphone in Device Toolbar?ruthiemaykanga wrote:Audacity says that the microphone is usable and is monitoring something that is not my microphone.
[windevtool][/windevtool]
