To Know file type
delta
To Know file type
Post by delta » Tue Dec 23, 2014 7:04 am
Recently started learning Audacity. I have a sound file in VLC Player. I don't know what file type is it. I would like to
insert it to Audacity and use it as MP3. Without knowing file type I tried to just drag it from VLC player to Audacity. Once I drag
that is not going to Audacity. How to bring it into Audacity ?
There are around 15 separate files. From each file I have to remove some voice from the beginning. How to do this please.
delta
file type
Post by delta » Tue Dec 23, 2014 11:10 am
I have saved in laptop some sound files as mp3.
Out of that 2 files are .partial
I mean after the file name there is .partial in the place of extension name.
How to change this to mp3 ?
What does it mean by .partial and how that name is coming ?
Re: To Know file type
Post by Gale Andrews » Tue Dec 23, 2014 12:58 pm
delta wrote:Recently started learning Audacity. I have a sound file in VLC Player. I don't know what file type is it.
I suggest you enable Windows to show file extensions, which are the three or four letters after the file name. The extension tells Windows what the file type is, and then it knows what applications (programs) can open that file type. See Show extensions for known file types in Windows.
delta wrote:I would like to insert it to Audacity and use it as MP3. Without knowing file type I tried to just drag it from VLC player to Audacity. Once I drag
that is not going to Audacity.Audacity cannot import all file types as shipped.
I suggest you install FFmpeg then Audacity can import most types of file. See http://manual.audacityteam.org/o/man/fa ... tml#ffdown for instructions.
delta wrote:There are around 15 separate files. From each file I have to remove some voice from the beginning. How to do this please.
If you mean to delete all that audio (voice and everything else), drag-select in the waves then press Delete on your computer keyboard.
If you mean remove the voice from the audio and leave the rest of the audio there without deleting it, see Tutorial - Vocal Removal and Isolation - Audacity Manual.
Re: file type
Post by Gale Andrews » Tue Dec 23, 2014 1:09 pm
delta wrote:I have saved in laptop some sound files as mp3.
See above. Changing the extension of the file name does not convert it to that file type.
The file may not even be complete. Some application that downloaded the file may have given it ".partial" extension for that reason. To find out what file type the file really is, download "MediaInfo" from http://mediainfo.sourceforge.net/en/Download/Windows. Get the version without installer, because the installer may have malware or adware.
If MediaInfo cannot open the file, then it is corrupted and probably not usable. If it is a WAV file, Audacity "might" be able to import it by using File > Import > Raw Data... , but even if it is a WAV that won't work properly unless you know all the details of the file already, like encoding and byte order. See http://manual.audacityteam.org/o/man/file_menu.html#raw.
