Linking Lame to Audacity [SOLVED]
royofherts
Hi I am operating on Windows 7 I have down loaded Audacity and Lame again but can not export as MP3 any advise please.Roy
- Quality Assurance
Re: Linking Lame to Audacity
You should be using the latest Audacity version (currently 2.0.6) from http://audacityteam.org/download/windows. When you have 2.0.6, please follow http://manual.audacityteam.org/o/man/fa ... .html#lame to make sure you download and install the correct version of LAME.royofherts wrote:Hi I am operating on Windows 7 I have down loaded Audacity and Lame again
If the problem persists after following the above, please say exactly what the error message says when you try to export and attach the log file from Help > Show Log... . Please see here for how to attach files: http://forum.audacityteam.org/viewtopic ... 49&t=64936.royofherts wrote:can not export as MP3 any advise please
If LAME is installed correctly but you are putting dots (periods) in your file name, add ".mp3" (without the quotes) after the end of the file name before you export.
royofherts
Re: Linking Lame to Audacity [SOLVED]
Hi Thanks for your help it is now working.RoyGale Andrews wrote:You should be using the latest Audacity version (currently 2.0.6) from http://audacityteam.org/download/windows. When you have 2.0.6, please follow http://manual.audacityteam.org/o/man/fa ... .html#lame to make sure you download and install the correct version of LAME.royofherts wrote:Hi I am operating on Windows 7 I have down loaded Audacity and Lame again
