how to silence audio [SOLVED]
stevenknowels
Post by stevenknowels » Tue Nov 25, 2014 10:39 pm
i used audacity years ago and im sure there was a way to mute part of a recoding, but i cant find it. can anyone help?
Re: how to silence audio
Post by steve » Wed Nov 26, 2014 3:30 am
"Edit menu > Remove Special > Silence Audio (Ctrl+L)"
http://manual.audacityteam.org/o/man/ed ... ecial.html
Is that what you're looking for?
stevenknowels
Post by stevenknowels » Wed Nov 26, 2014 11:45 pm
thats it. thanks
