Audacity query - mixing music with speech?
happy37
Post by happy37 » Fri Nov 14, 2014 10:09 am
Hi everyone,
Good morning.
I am using Audacity version 2.0.6 on Windows 8.1.
Obtained using the zip file.
I am looking to make a short demo of a podcast for a radio show. This demo of my voice will be 5 minutes long.
Now, the first thing I need is a good quality microphone. Is this one any good?
"Behringer XM8500 Ultravoice Dynamic Cardioid Vocal Microphone"
http://www.amazon.co.uk/gp/product/B000 ... ge_o00_s00
Secondly, I will using that microphone to record myself reading a script to do a mock radio show. Once this is recorded and saved in Audacity, I want to add/fade in/fade out some short bits of music.
How easy or difficult is this to do using Audacity please?
Any tips or any guides available on the Net?
I use Audacity quite a bit, but I have not attempted to mix music and speech together yet.
All pointers welcome.
Many thanks.
Happy37
Trebor
Re: Audacity query - mixing music with speech?
Post by Trebor » Fri Nov 14, 2014 10:26 am
happy37 wrote:I use Audacity quite a bit, but I have not attempted to mix music and speech together yet ...
There is a tool in audacity called "AutoDuck" can be used to automatically reduce the volume of music when the DJ speaks. Some trial-and-error is required to get the AutoDuck settings correct.
One method of manually fading-in and fading-out is using Audacity's "envelope tool" ...
Envelope tool Demo.gif (418.34 KiB) Viewed 443 times
