Exchanging projects with a friend
bope1900
Post by bope1900 » Wed Nov 12, 2014 1:33 pm
Hi,
I sent my "save project" by email to my friend but he can't open it and even when he send me his file save it with "save project" i can't open it. there is some way to open his project in my computer??
thank you
Reason: Topic split and given relevant title
Re: Exchanging projects with a friend
Post by steve » Wed Nov 12, 2014 3:49 pm
bope1900 wrote:s some way to open his project in my computer??
Yes, you need the "whole" project, not just the AUP file - you need the "_data" folder as well, and your friend needs to ensure that there are no external dependencies.
Assuming that you are both using the current 2.0.6 version of Audacity (available here if you don't have that version: http://audacityteam.org/download/) see here in the manual for instructions how to send a project: http://manual.audacityteam.org/o/man/au ... .html#move
