not responding
edwaptone
not responding
Post by edwaptone » Mon Sep 29, 2014 1:46 am
i just accidently sent the audacity file i was working on from the desktop to the recycling bin, the audacity file now says not responding. will i loose all my work? can i get it to respond?
help!
using vista
Trebor
Re: not responding
Post by Trebor » Mon Sep 29, 2014 2:46 am
Open the Recycle Bin then , right mouse click on the accidentally binned item , then select "Restore" from the menu which appears. The item then goes back to where it was before you binned it , Audacity should then be able to see it.
http://windows.microsoft.com/en-us/wind ... ecycle-bin
If you've emptied the bin you're in trouble , you could try Recuva to recover deleted items , but don't bank on it working.
Re: not responding
Post by Gale Andrews » Mon Sep 29, 2014 4:24 am
Are you actually using current Audacity 2.0.5? See the pink panel at the top of the page.
For me (Windows 8.1, Audacity 2.0.6) Audacity does not freeze if I delete an AUP file that is open in Audacity, and I would not expect it to. If I edit the project, Audacity is writing the unsaved changes to the AUTOSAVE file (it's a temporary AUP file, in effect).
If I save the project, Audacity recreates the AUP file.
If the project contains a WAV file that I imported without copying it in, deleting the AUP is still not a problem.
Or do you mean you sent the _data folder to the Recycle Bin? In that case, Trebor's advice should work.
