overdub
yle82
overdub
Post by yle82 » Sun Sep 28, 2014 3:47 pm
I saved my recorded voice on an instrumental song.Now I want to continue recording,and while singing formed a new track,but when playing back the result the instrumental part gets double!how can I fix?thank you
Re: overdub
Post by steve » Sun Sep 28, 2014 3:49 pm
Set the recording device setting in the device toolbar to the device that you are actually using (NOT "sound mapper" or "Stereo Mix" or "What U Hear").
See also in the manual: http://manual.audacityteam.org/o/man/tu ... rdubs.html
yle82
Re: overdub
Post by yle82 » Sun Sep 28, 2014 5:36 pm
I tried to check the recording settings,but I could not fix.Can I record on the same vocal track that I saved without another track starts under the first?
