selection tool not working
edwaptone
Post by edwaptone » Fri Sep 26, 2014 11:10 pm
hi, selection tool is not working. whenever i click, the line appears either to the left or the right of where you have clicked, sometimes it doesnt register at all
:? :oops:
i am using windows, please help have tried dependencies and reinstalling but cant figure it out
Re: selection tool not working
Post by steve » Sat Sep 27, 2014 12:36 am
You may have accidentally enabled "Snap To" http://manual.audacityteam.org/o/man/se ... .html#snap
Ensure that the "Snap To" check box is not selected.
