audacity not saving
Re: audacity not saving
Post by Gale Andrews » Thu Dec 11, 2014 9:51 am
Katzenfreund wrote:
Gale Andrews wrote:Please be careful with Windows XP.
For some extra protection you can install http://technet.microsoft.com/en-us/security/jj653751 .
Thanks for the advice Gale. But following the link, the EMET toolkit talks about enterprises. Do you know if it's also suitable for private individuals?
Yes you can use it as a private individual. See for example http://www.howtogeek.com/190590/quickly ... lkit-emet/.
Katzenfreund
Post by Katzenfreund » Fri Dec 12, 2014 7:33 am
Thanks for the reply and the explanatory link. You obviously know much more than just Audacity.
