Radio sounds through recordplayer?
I hear very often over time a voice from the radio through my software playthrough on my recordplayer. How can that be? How do I fix that? And I don't get sound to the speakers of the record while playing while playing a CD does give sound.
Re: Radio sounds through recordplayer?
Do you have any orange and white towers in your neighborhood?
http://kozco.com/pix/KABC-Full.jpg
A teleproduction company got a really good deal on performance space in the industrial park under that tower. They eventually had to stop using it because it was impossible to shoot sound. KABC Radio would show up everywhere, all the sound lines and microphone amplifiers.
- Quality Assurance
If you are trying to use external speakers connected to the turntable, look at the manual for the turntable.nienke64 wrote:And I don't get sound to the speakers of the record while playing while playing a CD does give sound.
If you don't hear sound in Windows Media Player, please see: http://manual.audacityteam.org/o/man/fa ... k.html#usb .
